SoCalLuke
New here, and of course need some help. My searches haven't popped up with the same scenario. So I thought I'd ask the experts here:
Have 2012 RAM Power Wagon with 5.7 Hemi in it, with 92k miles and have owned it since 8k miles.
Late Dec. While towing, I had a blow out (going up hill) on one of the 4 trailler tires and dragging the blown tire cause an increased load on the engine, and the RPM went sky high until I was able to pull over, less than a mile. (I was in Tow/Haul mode.)
As this was happening the check engine light came on, was flashing, and began beeping. The radio, was on, but I also think the engine died when I came to a stop, (but not 100% sure.)
Changed the trailer tire, popped the hood. Oil level was fine and all temps (coolant, oil, transmission) were all fine. So I limped along without straining the engine and checked the code at the next AutoZone. It was P0301.
Ended up finishing the trip and as long as I kep the rpm under 4500 rpm the truck drove fine. Even wheeled it a bit. Then drove home. It was only when downshifting or going up an incline, and going over 4500 rpm which would cause the CEL to flash and beep. Then once the rpm's dropped the light would go solid.
Got home (whether with a trailer or not, whenever I hit 4500rpm would cause the CEL to flash.) Mechanic verified the same code P0301 and replaced all spark plugs, coils, and air cleaner. No CEL light and it ran fine.
One week later, I was playing around with the tow haul mode, while driving on the freeway to see where it shifted. (I just moved from 34x11.5 tires to 35x12.5 and was curious.) Well this spirited driving in tow/haul mode caused the CEL to flash and beep. Slowed down, took it out of tow haul mode and then the light went solid. Kept the rpms down and it drives fine. Mechanic checked and the code was again P0301 and U1449. It was Friday afternoon, he looked at a few things but didn't take anything apart. And reset things.
Today I put it on the floor and watched the rpm climb, when it hit 5000rpm, sure enough the CEL began beeping and flashing. Drove normally, it went solid. Stopped and it went out didn't come back on.
Any guidance? or Suggestions?
