SoCalLuke
Thanks as always @Tach_tech !
Two more questions.
1. When you have replaced cam and lifters, with OEM parts - Have you had any clients get another 80-120k miles yet? If so, are the replacement parts holding up? (or is this an every 100k miles thing?)
2. While the heads come out for the cam / lifter replacement have you had luck replacing exhaust manifold bolts with Grade 8 or Grade 10 bolts? (Thinking about a preventative mod now. Since both driver and passenger had broken/stuck in bolts in the past.) Thinking I'd rather do that now, then potentially deal with it later.
Two more questions.
