Haas
This should be something I should be able to figure out, but no luck so far. My drivers side door develops a bad squeak when opening and closing it. I've tried spraying white lithium grease from an aerosol can on it. It's works for about 5-7 days, then the squeak comes back.
Had someone suggest oil first, then coat it with grease after oiling. Tried it, same result.
Is the hinge just shot? The door doesn't sag or anything, and nothing looks worn on the hinge. Only 28,000 miles in this rig, what else can I try?
