dash rattle
cux211
NE PA
just bought a 2013 ram Laramie I only have 300 miles on it and a rattle/vibration started in the top of the dash in the center right in line where that center speaker is when I put pressure on top of the dash it stops anyone else come across this issue any easy fixes I hate to go to the dealer for this cause they're going to want me to leave it and having to find rides and all that bs
Appauldd
2012 Ram Big Horn
My 12 has the same problem. If you find the fix....please let us know.
2serious
long island
Same problem here. Been back to the dealer...they hear nothing.
Appauldd
2012 Ram Big Horn
The rattle in mine only happens when you drive over a series of small bumps. It is quite obvious.....and ANNOYING.
WhiteExpress
Midland, TX
If you're the adventurous type, you can take your dash apart, and find the contact point. Then put the 'soft' side of velcro on it (the peal and stick kind)
Almost always kills the annoying little rattles.
CAP LOCK KID
Ontario
2013 Sport QC 4x4
5.7L HEMI
Me too. Only seems to be at a certain temperature. When cold out, it is not there, as the truck warms it comes on strong and then gets less and less.
Very annoying sound. I had dealer look but got the "we don't hear it".
emjohn4
You mean like this? (Skip to 0:45 and turn your speakers up).
[yt]PIccsiQzLR0[/yt]
Dealer says they "cannot duplicate." Drives me fricken nutz.
Same as you, I can put slight pressure center dash near the speaker, and it quiets right down.
I'm going to pull the dash apart this fall (too hot here in the summer, and we'll have a nice garage by the fall) and put some felt in there.
WhiteExpress
Midland, TX
YUP! I hate that one :fc5716bd:
I think the issue is dealer techs almost always drive pieces of ****.
So they have learned to tune out little rattles n ****. I wish I could take it to a Benz Dealership. They'd be like "WTF This whole thing is a rattle box!"
Appauldd
2012 Ram Big Horn
That video is exactly what mine is like...but yours is even worse. UGH. We need to find the fix.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I think I also have this little devil in mine.
skirider
Anyone find a fix. My 2011 sport is driving me nuts.
About to pull it apart. The slightest preassure on top of dash in middle and goes away
SWAMP RAT VII
YOLO,CA
2017 RT
Took my 2014 into the dealer and he knew exactly what to do. He pulled a report that showed the dash rattle was a problem on many Rams. They installed more foam under the dash. I have not had a problem since. Kindly let your dealership know to research this. It is a common problem on these trucks.
RamCares
n/a
n/a
I have that same noise.. but mine is in my full console...
Hi JaredRAM2015,
Depending on your vehicle's build date, this TSB may apply:
TSB NUMBER: 23-001-15
GROUP: Body
DATE: January 09, 2015
SUBJECT: Lower Center Instrument Panel Bracket Fasteners Loose
OVERVIEW: This bulletin involves tightening the lower instrument panel bracket fasteners to the proper torque specification.
MODELS: 2015 (DS) Ram 1500 Pickup
NOTE: This bulletin applies to vehicles built on or after November 15, 2014 (MDH 1115XX) and on or before November 18, 2014 (MDH 1118XX).
SYMPTOM/CONDITION: The lower center instrument panel fasteners were left loose during vehicle assembly. This condition may result in a buzz, squeak, or rattle noise coming from the lower center instrument panel area.
skirider
Any more info. Mines out of warranty
TerraNewf
NL, Canada
I have the same annoying rattle, I turn up the volume and cancel it out.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You may be able to gain enough access to add foam by just removing the radio and bezel. It will take you all of 5 minutes.
skirider
Ok were are we adding phone
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
If it allows you enough access, you said that a slight downward pressure cured the rattle. I'm thinking a slight upward pressure will do the same?
Really, place it anywhere you can that works. Removing the radio will let you see a large cavity in the dash. There is a lot going on in the center, but you may be able to wedge something in.
Another option is to remove the driver instrument cluster. It is also very easy to get out, has only one plug and is completely unobstructed behind it (easier to look around in).
emjohn4
Check out the comments on my youtube video posted above.
I found the rattle - it is at the junction of the defrost vent and the HVAC box. If you pull off the radio bezel and radio out, the defrost duct goes into the HVAC box right there. The rattle is actually the duct rattling, and the noise travels up through the duct and out the defrost vents (i.e. appears to come from the dash). I put some foam between the defrost duct and the HVAC box around 18k miles (Summer 2013). I'm now at 33k miles (no - I don't drive a lot), and the noise has never returned.
