Dash Speakers
Kapt
3L
Wanting to put dash speakers in my 04 Ram. Does the dash piece come off to access the ares for dash speakers? On my old Challenger the piece was held on by clips. I'm guessing it's the same with my truck? Figured I would ask before I go out there and start prying on my dash
Tray Burge
On the porch
I have an 03, yes it's clips, but expect the dash to crumble/break up when you start pulling on it. The plastic is an inferior ****** blend- on going problem if you haven't already heard.
Kapt
Kapt
3L
No, I hadn't heard that. After 11 years of being in the sun, I imagine it will be fairly brittle. I guess maybe I really don't need dash speakers. They were just the crappy paper ones I took out of the Challenger anyway. I s'pose if I do it, I should wait until I have decent speakers and a new dash piece lol
Thanks for the reply
Tray Burge
On the porch
Dodge tried to blame us the consumer and said it was due to not keeping the plastic conditioned, but the truth is they used improperly formulated plastic and there's a lot of pissed off Rammers out there. Google ram and dash cover and you'll see what I'm talking about.
justin13703
MD
Just use a panel popper and pop each clip location and you should be ok. And if it does break I'm sure that dash panel can be found on rockauto or something for relatively cheap.
KPietriyk
NE Pennsylvania
I've had the one in my 05 out several times, no problems with the clips or the panel, goes right back in every time. I wanted to put a speaker for my 2-way radio in the dash, so the sound from that would be more directed towards my ears instead of into the carpet.
justin13703
MD
Mine on my 08 has been out plenty of times too, but his being an 04 and not knowing how much direct sun has been on it, you do have to be a little careful with the older plastic pieces.
