daytime running LEDs
k1ng87
anyone put daytime running LEDs in their RAM? Also, will 2015 RAM have daytime running LEDs? If so, would those fit in a '14 if they did?
firemedic10584
Central Fl
Use the search function, I myself have started a few threads regarding DRLs. The short version - I ended up buying the Philips LED 8 DRLs and mounted them on the lower plastic piece in the bumper and they look stock. Search around, I have a thread on those with pictures and reviews.
mmwaggie
The problem with the search function on this forum, and most others, is that strings 3 characters and under are ignored. So searching LED DRL will not return any searches and few people actually call them daytime running lights. I'd suggest doing a google search instead using a search modifier: site:ramforum.com
K
k1ng87
thanks guy...yeah, tried using the search function but didn't have much luck....
K
k1ng87
hey fire, you talking about your light bar install? I thought those were too bright for daytime running?
mmwaggie
I believe he is talking about these. They are very good DRLs.
InspectGWS
Houston, TX
2014 JEEP GC SRT8
I installed the same DRL's in the same location as firemedic...I believe this is might be his RAM, I pulled the pic right off of AMAZON...
K
k1ng87
bah...but I have tow hooks in that area....anywhere else I could install them?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
could move them in more towards the center?
firemedic10584
Central Fl
No, I have DRLs as well as the 20" LED bar. The DRLs come on automatically when the truck is on and dim when the parking lights are kicked on. The LED bar is on its own switch.
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
What/where did you hookup to have them come on with truck?
K
k1ng87
Boldadventure...do you know where I can get those halo assemblies you posted a pic of?
firemedic10584
Central Fl
Smuuth
I have a 2014 Ram 1500 Sport and wanted the LEDs to come on as DRLs. I was very frustrated after going to two dealers and being told it couldn't be done or that option was only available for Canadian or Fleet vehicles. One dealer even said there was a different wiring harness for vehicles which have the DRLs which I knew was BS.
Well, here's how you do it: The option code to enable the DRLs is VIN-specific. Someone has to have access to the Chrysler server and through that, they can send the option code for the DRLs down to the specific VIN to enable them. After that is done, access the vehicle through the OBD II port and the option to enable the LEDs as DRLs is available.
They will NOT be on if the vehicle is in Park or if the emergency brake is set.
