A lot of the DTCs will be "lost communication" with some module. Those would go away once the engine was running after several minutes. Pay attention to any code stored in history. They will not trigger a cluster light (unless the cause is present) but will show up on the dealer's scan tool. Codes stored in history will disappear as long as the cause is gone and after a pre-determined number of ignition cycles.Thanks. Reason for asking is I went to see truck I'm looking to buy at the dealership today. they couldn't start it so they jumped it with a battery pack. Then i saw the CEL and the sales person assured me it because of the dead battery. We shall see when I go back on Friday.
I wonder if the 2018 2500's require the security bypass module like my 2018 1500. Would love to hook up my alfa OBD to this truck and read the codes.
I got mine form KAODTech. Are the interchangeable between 1500 and 2500?What he said...
And YES, the 2018 2500 still requires the same security bypass cable as the 1500.
Good to know. Did not realize thatYou don't need the security cable to just read stuff, only to make changes. Plug in an MX+ and it will show you the stored codes, even without using AlphaOBD. The MX+ has very good diagnostics built into its proprietary APP. If you want to dig deeper link your Alpha and look at it too.
Yup, the salesman assured me 2 new batteries. Since i don't believe them i took pictures of the current ones in the truck and we will seeA lot of the DTCs will be "lost communication" with some module. Those would go away once the engine was running after several minutes. Pay attention to any code stored in history. They will not trigger a cluster light (unless the cause is present) but will show up on the dealer's scan tool. Codes stored in history will disappear as long as the cause is gone and after a pre-determined number of ignition cycles.
Since the vehicle's electronics never completely fall asleep, for example, the RF Hub, which wakes up periodically to sniff for its FOB signal, will drain the batteries after several weeks of the truck sitting idle. If you like the truck, have the dealer install brand-new batteries.
The bypass cable is interchangeable.
THATs wat I hate about these new systems. You used to get like some type of warning, when battery going. NOT anymore, 1 day good, next day BLAM !!!!! Gotcha.My 3500 batteries lasted almost 5 years before they gave up the ghost. No slow crank, no CEL, nada. We were at a campground and it just didn't start one morning. Thankfully we also had the wife's car so I was able to jump it and drive to the part store to swap them.
What code was set with the CEL? You can pull the code with a simple OBD reader. The fact the CEL cleared may have nothing at all to do with the new batteries. Since this is a used vehicle you are buying I would want to know positively what caused the CEL before laying my cash on the table.i am happy to say the the CEL was due to the dead batteries. The dealer installed 2 new Mopar batteries and the CEL went away after a short test drive
