dead factory 7 pin plug
Dusty
Rochester, New York
My '12 Ram 3500 has the factory tow package. Problem is the plug at the bumper is dead but all fuses in the box are good. The lever controller on the dash shows power on the screen. I'm thinking I need to look at a factory wiring diagram to run down the tow wiring plug connections.
Are you in a winter environment (cold, high moisture, snow, road salt)? Based on the description in this thread of the things you've already found and your symptom set, as well as the year of your vehicle, I'm suspecting the TIPM may be the source of the problem.
Some years the TIPMs had to be flashed.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 010909 miles.
poppoplou
6.7 turbo diesel
On my 2011 2500 the problem was the TIPM unit. $1600 installed and programed at the dealer.
