Decided on lift / level . . thoughts?
AOFA
Cummins I6
So I think I have it narrowed down, thanks to reading these forums and the help of members on here.
I will be getting a 2014 1500 Crew cab 4x4 ecodiesel in mid June. I want a lift that is noticeable but not too big. I think I have decided to go with bilsteins @ 2.1, 1.5" body lift and rear adjustable coil block (1.0, 1.5, 2.0) to get the proper rake once the front end is done. Also prepared to replace the UCAs with Zone if need be. Tires and rims possible down the road, but nothing over 35".
Thoughts?
KCTHUNDER
Kearney MO
6.7 CUMMINS
may look funny with 3.5 or so inches of lift and doing tires down the road....
AOFA
AOFA
Cummins I6
Yes I realize.. I will have my **** Cepek Fun Country tires on.. they are def more aggressive and larger than the good years..
KCTHUNDER
Kearney MO
6.7 CUMMINS
awesome! well ya did your homework and plan on the UCAs right off the bat.. that's the main thing. im sure itll look great! just be sure to fill out your sig with all your info and a pic!
AOFA
AOFA
Cummins I6
Thanks man.. for sure I will. Truck is on order, so it will be a couple months till this is all done.
aIIan
South Florida
2O14
I stole this photo from another board member (012RAMbo) but this is what our trucks look like with approx. 4" of lift and stock wheels & tires, not too goofy imo.
AOFA
AOFA
Cummins I6
Thank you, That is exactly what im looking for!
Cheers!
Cliff p
HEMI 5.7
Bumping this up a bit because I'm about to pull the trigger on the Rough Country level/lift kit...
That picture above looks strikingly similar to my Big Horn CC, at it's stock ride height. Are you sure that's a pic of a lifted Ram? I have that kind of gap in the rear as the truck sits, from factory.
Just curious is all.
012RAMbo
West Monroe, La
Yea, it is lifted 1.5" in the rear on that pic and 4" in the front. But it is also 2wd and I believe they are about an inch or so shorter than a 4wd.
Hemidog22
Anyone have any idea what a 09 would look like with 2 inch lift (level kit) and factory
20 inch wheels?
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
This is true and does look like a truck with maxed bilsteins on 4wd ram
20 inch wheels?
There are many on the net.
Google 2" level kit for a Ram 1500 and you see many from different forums and this one
Sladerade
North Carolina
Here is my truck when I had stock tires and Bilstiens @2.1
Wait a second... I'm posting from an iPhone?
