Decided to try some LEDs...
Platypusfetch
Peterborough, Ontario
Alpharex Pro G2 Projectors
First shot is low beams only (no fogs)
With Light Moses Premium 360° LED's
Second shot is high beams only (no fogs)
Auxito H7 LED's
Does your truck have Daytime Running Lights?
Ordered the Light Moses Premiums, for both Low and High beams.
High beams fired right up in my 2020 Ram 1500 Classic Express. (Alpharex G2 )
The Low beams? Stayed completely dead. No light at all...
What am I missing?
UnkoBro
Honolulu, Hawaii
What am I missing?
I have a 2014 Ram 1500; I have DRL activated on my BCM for my fogs; I have the LED bars wired direct to a "switched" fuse location in the fuse box under the hood. I also have "Disable Low Beam Dropout with High Beams ON" in the BCM (through Alfa OBD) which gives me all 6 lights on when needed. With your 2020 Ram, in order to do the BCM changes yourself, you'll need the Security Gateway Bypass Harness...hope this helps :)
Gregket1
Oregon
What am I missing?
Did you get this resolved? I installed the Light Moses lows yesterday and only one worked. I tried changing via Alpha OBD but still dark.
Gregket1
Oregon
One of mine worked, the other did not. Even after alphaobd changes it still didn’t work. I reached out to support and got no response after several days. Uninstalled and returned them via Amazon. Ordered Auxito Y13s.
I hope you have better luck. But based on Amazon reviews of bulbs and manufacturer, I doubt it.
