Deciding between timbren and air springs
DustanT
5.9l 24v cummins
I took mine 1" spacer out when I put the Timbergrove bags on because the extra height shifts the rearend over and the spring on the right side kept hitting the air bag.
The axle shifts while the suspension travels? that doesn't sound right?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
As you lift the truck the axle on our trucks will pull off center because of the fixed lenght on the track bar.
So raising the truck 1" plus the littke bit the bags raise it moved thevrear end over just enough to hit .
DustanT
5.9l 24v cummins
Oh ok I was trying to find some info on how the geometry works on the new link system.
