Deezee bedmat + bedliner
sbarron
Wasilla, Alaska
I have the DeeZee Bedmat over my spray liner. Been 3 years, zero issues. Velcro stuck, and continues to stick just fine to the liner, just needs to be warm, clean and dry before install. Use the cleaning solution that comes with the kit.
Edit: Added photo
Markcuda
Eau Claire Wisconsin
2026 Longhorn 4x4,short bed,22s,H.O twin turbos.
3.0 I6 H.O. Twin turbos.
I put a Dee Zee rubber bed mat in my truck a month ago and I sure like it.
Nothin' and I say nothing will slide very easy on it and that is how I want it.
clifford15
RI
CTD
I have a rubber bed mat. Not DeeZee but essentially the same. It sits flat as it can over the 5th wheel prep covers. It also stays down with the tonneau cover off or open at highway speeds.
Rzrman328
Rzrman328
The treeline
Which one do you have?
blackbetty14
CT
Hemi 5.7 VVT/Etorque
I also have the rubber deezee bed mat on my Linex bed. Fit and works perfectly. I hated the linex by itself as it is still slipper but when something slides it shreds it. With the bed Matt I get the impact resistance and stuff stays put, I mean so much so that u have to pick it up and wiggle it out vs just pulling and letting it slide out. Works perfectly for me as well. And its bumps on the back allow water to drain under and out so moisture doesn't build up. I've transported transmissions, engines, antique huge grandfather clocks and it's worked flawless. I've even spilled gas on it and did nothing. Best $60 I spent in the bed.
Check summit racing as I got it cheaper than amazon prob less than a year ago. But you have to order $100 to get free shipping which isn't hard to do!
Shady
Cummins
I just got the Line-X done, then put my custom made mat back in. It is a 3/4" thick stall mat that I got from my local co-op for about $60. It's heavy! About 130 lbs after trimming for length and wheel wells.
I love it. Nice to crawl on, but very tough. Nothing slides around on it too.
Sent from my phone using Tapatalk
Rzrman328
Rzrman328
The treeline
Damm...that's a serious bedmat....but I don't think my little 5.7 would appreciate haulin around an extra 130lbs all the time lol
Looks good though!
Shady
Cummins
Looks good though!
Lol, thanks. I see your point... My truck is a 3500 HD and doesn't notice.. it would probably help your traction a bit though?
Rzrman328
Rzrman328
The treeline
The biggest issue with the the deezee (Amazon) is people complain that they won't ship it flat and that it comes rolled up and has a hard time flattening. That's my biggest concern I guess.
sbarron
Wasilla, Alaska
That's true, and they recommend laying it flat in a heated area for a bit before install. I don't remember having any issues with curling after install. Granted, I'm old and don't remember everything as it actually was....
marine6212
I can't imagine the shipping/handling cost to send it flat! Much less some poor ups/fedx driver trying to load/unload off the truck.
Rzrman328
Rzrman328
The treeline
Are there local stores that sell the deezee bedmat? Maybe lowes or Home Depot.
Idk even know what places would carry these.
blackbetty14
CT
It comes rolled up. Honestly it flattens out immediately. It doesn't actually want to be rolled up. Either way throw it in your house overnight and flatten it out. Then throw it in the truck and be done.
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
This is what I want to find for mine. Unfortunately the local TC doesn't carry it. Haven't been able to find any other suppliers in the area yet.
