Def delete. 2016
Cadilac joe
Diesel
What is all needed to do this? I keep getting the codes that’s my def needs work. So I’m thinking deleting it. Can I just get the efilive and block off plates and be fine. Or does this efi live need to be programmed to the truck?
2016 2500
C
Cadilac joe
Diesel
Could of just gotten bad def from the auto parts store.
mtnrider
Georgia
EFI live (or Ezlynk) is just hardware. You would need custom tuning to go with it.
Then there is "intact" tuning where everything stays in place and you disable the DEF system (DPF still works and regens) and EGR is disabled. Then there is full delete tuning where you remove the DPF on top of that and can remove everything.
C
Cadilac joe
Diesel
I’m think I just want to delete and leave my old exhaust in. Can I do this with just a programer
mtnrider
Georgia
Not "just" a programmer. You would need ezlynk or EFI live (hardware) then find a tuner that does intact tuning. You will not find a off the shelf programmer to do that.
Immerge
