Goose55
- Aug 29, 2020
- 696
- 398
- Location
- Ajo, AZ
- 2019
- Cummins High Output 6.7L
Below, please see one of the old, cheap chinese Nexen stock front stock tires I replaced in Febr on my 2019 Ram 3500 Cummins Diesel. I took one of them to the dealership to show the uneven outer wear caused by their squirrelly factory toe in front alignment.
Last week I took the tire to the landfill and while dumping it saw this large chunk of the tire's casing missing, next to the inner bead, and all that was done was sticking some kind of adhesive caulking around the void, and calling it good.
It's unlikely that the tire was mounted to the wheel where these Nexen tires are made in China. I'm assuming the tires were shipped to the Ram HD Assembly point in Mexico, and the tire was mounted there. In the pic you can see that this defect was on the inside portion because of the browning, and thus out of sight and out of mind. Not good!!
These tires were rotated at least a couple times at LHM Avondale, AZ and no one ever said a word to me. The defect was plain for anyone to see because in the pic you can see next to the void the portion that rested inside the wheel was not exposed to the elements and is much darker/ black. That damage was therefore plainly visible. The Cummins diesel is a very heavy engine, so there is much greater stress on the front tires.
I'm no tire expert but this doesn't look very safe. I had this tire rotated at the Dealership at least twice, and no one ever said anything :-/ My understanding is that sidewall repairs are illegal. How was this overlooked?
