Defroster/ vent control
preston75052
Arlington, Tx
5.7L
Whats up guys,
Question, do any of you know which actuator controls the vent/ defroster? Not the temp one from hot to cold. Right now its stuck on front facing vents and been trying to switch it to the defroster in the mornings.
If so, is that a easy one to repair or am I facing the tragedy of pulling the dash out?
Any and all feedback is appreciated!
Thanks,
SYKRAMMAN
Banned
Jersey shore
06 Mega
Whats up guys,
Thanks,
It’s not all that hard to remove the dash just time consuming, it’s the best way rather than butchering the hvac box like heater treater states. I think it’s the mode 2 door that controls the direction but while your in there you might as well change them all out because they will break eventually. 9\10 it’s the door coupler that breaks, not the door itself but but when replacing, I wouldn’t use oe, use blend door USA or heater treaters doors as they are a lot stronger and not plastic either.
preston75052
preston75052
Arlington, Tx
5.7L
Is there a way to get to that door without removing the dash?? I know my Mechanic replaced a couple about a year ago. So for now I would be interested in replacing that Mode 2 "if I can get to it without removing the dash"
SYKRAMMAN
Banned
Jersey shore
06 Mega
No, the dash has to be moved to access it, the “mechanic” should’ve recommended replacing all the doors at once at that time. Would’ve been smart and cheaper.
You can do it, just take your time and take pictures of the process while proceeding. I did mine in a few hours.
preston75052
preston75052
Arlington, Tx
5.7L
This may help,,Just did mine
What year is your truck? Mine is a 07. But I called my mechanic yesterday and come to find out he did replace all of them. So it's under warranty and the truck will go back to him.
Runaround
Silsbee
I have an '07 that the blend door makes a load closing or opening sound when switching modes. What is the cause and how do I fix it?
