Deleted
matt.davidson09
2013 RAM 2500 Laramie Mega Cab
6.7L Cummins
deleted
EWC88
Southern NJ
Superbrightleds(dot)com. Just put truck info in and they'll have them listed, or if you have any numbers on them search that way. Just pop them in just like you took them out and you'll be good to go!
Trenton
swing by dealer you need bulbs and the bulb holders hope fully you did not melt the controls if you did you will need to pick up a new or used one
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
This is definitely a concern I have at the moment...the bulbs look mighty scorched around the base/bulb holder. Thanks
That is the way they look burned out, you can get a 3 bulb kit complete with sockets, original Mopar parts, from Amazon.com for around $9.00. I ordered a set for my truck, worked great.
Treeshark
Maryland
2005 Ram 1500 ST 4x4
4.7 Magnum V8
I have some of the same problems. Are all of the lights on the dash and cluster LED?
Harley Harrold
Mississippi
5.7L HEMI
I don't know about trucks before 07', I know on my truck it has only 5 bulbs in the gauge cluster. All the indicator lights are built in LED's. I have three that don't work in my gauge cluster, so I plan to pull the gauge cluster and try to fix the problem. I am hoping to use defroster grid liquid repair fluid to fix what I think is cracked circuits.
WulfGang
PA
I don't know about trucks before 07', I know on my truck it has only 5 bulbs in the gauge cluster. All the indicator lights are built in LED's. I have three that don't work in my gauge cluster, so I plan to put the gauge cluster and try to fix the problem. I am hoping to use defroster grid liquid repair fluid to fix what I think is cracked circuits.
If you suspect cracked circuits then it could be cracked solder points.
This seems to be a recurring nightmare since the 'world standard' (sic) is now LEAD FREE solder. Well... after cycles of heating/cooling and some vibrations thrown in for good measure, the solder points start to crack.
I've seen this already in PS3's, HD TV's, the tach on the Dodge RAM's and now, if you are onto something, the circuit boards for the lights.
