Demon Powered Ram
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
I would lose my license in that thing, but I would have a lot of fun doing it. I've got a thing for RCSBs, a fast one would be a blast.
It’s definitely a blast to drive! It will be awhile before I can tune it to the 800+ hp the motor is designed for. I have to beef up the rest of the drivetrain. My tuner says it’s probably putting an estimated 600+rwhp so I’m trying to take it easy on it, difficult task.
Tray Burge
On the porch
MOPAR78, is the final result of your build you've been working on for a couple of years now?
Oh my, that's about the nicest truck I've seen!
Wow, just no words to express my admiration.
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
Thanks! No I've still a ways to go. I'm waiting on a new throttle body to come in. It's a Demon 170 TB 105mm. I'm right at 415,000 miles on the original front and rear end. Their holding up but I've about made up my mind when I upgrade them to switch to the 3.92 from the 3.21's that are in it now. My next planned mods are upgrading the pulley setup to an 8 rib with a smaller pulley to increase boost on the Whipple to get the designed 800+ HP out of the Demon LB. Also get the transmission and transfer case built to handle the HP. I'll pull the trigger on that once I get the Demon LB paid for. Thanks again!
That's a clean looking RC SWB you have!
Tray Burge
On the porch
Thank you, so this is a production truck?
Didn't even realize this was available in this configuration, cool truck!
diymirage
i might be old, but when i hear demon, i think 225, or 340 if your lucky
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
No, it’s not a production line. I wish it was, I would have purchased one. As mentioned above, it is a project that I have been working on for a few years now. Good thing about it is that it is different than the other Ram's and the way I would have liked to have seen them to build one. Any ways it’s a build that I envisioned and it’s been rewarding to see it come together. I have saved quite a bit of money having done all the work myself. The only problem was the PSI spring failure on the 5.7 that set me back a bit. But the bright side is that now it has a better motor in it.
MOPAR78
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
Oh yes, the 340 6 pack was a classic and collectible!
Tray Burge
On the porch
You obviously need a new project, let's trade. lol
Tdodge21
