Diablo catch can?
Sybil
Anyone have any pics with the Diablo catch can installed on their truck?
Instructions show a Jeep lol
lonewolf2873
Rochester Hills, Michigan
2014 Ram Crew Cab 4x4
Either hose can go to either nipple. Extra barbed fitting goes to PCV hose from can.
Your removing hose from PCV to intake, with the catch can hoses going to those locations, Catch being the separator between the intake and pcv.
lonewolf2873
Use hex head bolt thru bottom of catch can mounting bracket. Bolts to threaded hole in passenger side ,front of motor. Long hose goes length motor to intake. Short hose to pcv.
Sybil
Sybil
I guess you have to remove the plastic engine cover to see whats going on?
Sybil
Sybil
Thank God for the internet!! By the way they shorted me one of the brass nipples and of course no one had one....
jay c
Las Vegas, Nv
From your pic it looks like you have all you need. Two brass fittings on the can and one for the throttle body. The long hose attaches to the PCV valve without a brass fitting.
jay c
Las Vegas, Nv
Sybil
Sybil
A ha...The Billet technologies "how to video" uses 2 nipples for some reason but now that you mention it he should have just discarded the rubber boot and just attached the long hose directly to the manifold like you did.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The Diablo catch can is actually made by Billet Tech, and they just put the Diablo logo on there for them. It does not require the 2nd barbed fitting to attach the new line to the PCV valve, but BT puts it there anyways because a few people complained that they had trouble removing the factory line from the PCV valve...mine did not need the 2nd barbed fitting to make this connection.
Sybil
Sybil
Thanks. Makes sense. It says it will work on a Challenger to. Does it bolt to the front the same as it does on the truck? I need one for the Challenger as well.
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
It does, but on your truck you have a high mount location and a low mount location. I like mine sitting in the lower one. The upper one like in the video you watch you have to remove the wire harness plug before install.
From that hole if you drop down 4" and it's at 7 o'clock. Gravity helps pull what Evers in the line down to the can this way.
Sybil
Sybil
So there is another bolthole lower to mount it?
