- Apr 28, 2012
- 23,269
- 44,973
- 2010 Hemi Reg Cab 4x4
- Hemi
Chalk test your tires is prob the best way to find how are they're going to wear down, Also use the TRA tables to give you an idea how much PSI you need to match your tires to carry truck loads.
I was running my BFG KO2 37x12.5x17 at 30 PSI, my Falken AT3W 315/70/17 at 35 PSI. i Run my current Patagania MT's 315/70/17 at 39PSI, and it's mostly cause the Pats have a tire thread that in theory actually wear down better if the center of the tire have a bit more contact with the ground as opposed to having the tire full contact path laying flat against the ground, otherwise i'll run the size at 35PSI. My tires do wear down evenly.
In Burla's cases he's running BFG KO2's in 295/70/17 now, i'll run them at 39-40PSI , rotate every 5k miles and measure the tires to verify even wear.
do you recall the load rating on your ko2's? mine is E 10 ply.
