Can you clarify this in layman's terms. Your saying the shop did the right thing because I asked them to fix it but actually didn't fix the hemi tick. So does that mean even though I got the new lifters and cam now, the motor will still eventually eat this new cam and lifters and I'll end up with the same problem all over in a few years?
It is a correct action from a shop to attempt to fix hemi tick by replacing a cam/lifters, sometimes it works. Clearly, the cam is in early signs of damage, real damage, that was fixed. There is no gauge on how long a cam will last with hemi tick, some 100 miles some 200k miles, and yes many examples here with hemi tick rams lasting 100k's miles and others that tick and die right away.
It would be impossible to wager a guess, we don't know if when you started redline did it stop the progression of the damage or not. Redline works about 80% of the time killing tick, and we have never heard again from any of these rams including mine and guys I talk to every day, it seams once the high ep additives are on the cam we fixed it.
Now, what we don't know is how come it doesnt work in 20% of hemi tick, does that mean on your cam where you have one lob showing wear that there is not enough lubrication to even get additives on the cam? Like I said, we simply don't know the root cause, only that it is more often then not that it is one single cam lob. I lave said from day one something is causing the restriction in the lifter bore and that creates enough back pressure to make these cam lobs wear, all of my theories and the coinciding theories of additives and the coefficient of friction all jive with each other. It is not coincidence that the one additive that reduces the coefficient of friction has silenced so many of these hemi ticks. For that group of dudes, we're good problem solved. Sadly, some guys fall outside that, and you are one of them. But you can still use that info to protect the new cam as best you can.
The scary part, this ticked right away? I assume they used moly lube on the install, so that doesnt bode well for your chances at killing the tick with a lube strategy. Nobody knows root cause of this, not your shop, not me, not fca, not uncle tony, not anyone I have heard of. If a lubrication strategy will work here at killing the tick, you will have to be bold with it, as in try stuff outside what we have known that fixed the 80%. That would like be stuff like high viscosity, powdered moly, chlorinated parrafins, and other things that I personally don't recommend. Or just use a lesser proven strategy like the reldine and lubegard threads and wait and see what happens. It sucks this hemi tick, it is a quagmire that some of us find ourselves in.
