Diff Fluid...Confirmation...
RAM_Designs
Rockwall, TX
6.4L Hemi
Just want to confirm that there is no drain plug/bolt on these 2016 2500's with 6.4L. I didn't see one when I went to apply some neo magnets on the underside of the truck, and my limited searching online seems to signify the same.
Basically I just need to get an aftermarket diff cover with drain plug, correct?
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Correct, no drain plug. Also, you will be limited at the current time to either a PML cover or a AEV cover if you are wanting diff cover with a drain plug. With the 2014+ 2500's, the rear sway and track bar gets in the way. Older models had more choices in covers with drain plugs.
Installed a AEV on mine but is pricey at about $300. I think the PML covers start around $200 or so and will get you a extra 1/2 quart capacity.
http://www.ramforum.com/f158/aev_2500_3500_rear_differential_cover_installed-89739/
PML Rear Differential Cover for 2014 and newer Ram 2500 with the AAM 11 1/2, 14 Bolt
Palomba
Wylie, Texas
no they do not. But I don't know if I would bother with an aftermarket, the reusable gasket seals very well, and I rarely ever see leaks, pull the 13mm bolts in about a min. drain and tighten them back up.
spoon059
Just north of Washington DC
6.7 CTD
No drain bolt. I just bought a vacuum pump and pulled out 3.5 quarts of fluid and re-filled. I found the rear sway bar to be more of a problem then the lack of drain hole. Refilling was a pain in the neck.
RAM_Designs
RAM_Designs
Rockwall, TX
6.4L Hemi
Well the filling is easy for me, I have a gallon bottle with a pump, with RedLine fluid, that I can just refill and re-use in the future. I mainly just want to make draining easier, not having to remove everything or use a pump, and getting some more capacity at the same time. I guess if an extra half quart is all we can get out of it, that's better than nothing.
RAM_Designs
RAM_Designs
Rockwall, TX
6.4L Hemi
Yeah I sent PML an email to get on the "waiting list" for when they get them finalized. Looks like I might as well do front and back.
stevenmicheal
