Difference in Base Prices for Rebem
Tonyd76
Seymour CT
I'm shopping around for 2022 rebel, and see varying base prices on the sticker. If they have the same motor, wouldn't the base price be the same? Or does it have to do with assembly date?
Dredger
SE Ohio
If you're looking at the original sticker, compare each of the optional equipment listings on the sticker to see if they are all the same.
T
Tonyd76
Seymour CT
IM TALKING ABOUT BASE PRICE
1979 300
Southeast PA
6.4L
The base prices do fluctuate from time to time. When I ordered my 2024 Ram 2500 in Nov. 2023, they had a $3000 rebate on them. The base price was $59370. Around a month later the rebates disappeared but they lowered the base price to $56340. This was for a Bighorn crew cab, short bed 4X4. The end result was basically the same price but the window sticker looked cheaper. Hope this helps.
T
Tonyd76
Seymour CT
Thank you for paying attention
tron67j
Maryland
You're being kind of snarky to people helping you. Your original post wasn't clear that you were researching the original window stickers, it was a valid assumption you were looking at the used window stickers. But if you look at the statement before the list of equipment it says that the list maybe be altered by optional standard equipment. It is possible the sticker you find may not contain features added that changed the value slightly. Could also be variables such as destination charge, which is different between Mexican and US built trucks.
farout75
Laurie, MO
2019 Limited
5.7 L
date of manufacturing has much about the price. That was during the Covid crap. Trucks were in short supply. Remember?
Sportyg
California
it also depends on where live for example for a new one here in CA you may pay 10/20K more depending on if it is fully loaded or not then you will in the south or east coast
nlambert182
Huntsville, AL
Some paints change the base price. For example, a pearl paint is often more expensive so that could be one contributing factor.
