differences gear knob 5 spd
reds
italy
cummins 5.9
hello
What is the difference between the 2 shift knobs on the dodge ram with manual transmission, my speed has in that order L 2 O
1 3 R
while others have the normal order 1 3 5
2 4 R
I thought it was a matter of ratios
grazie
R
reds
italy
cummins 5.9
hello
L 2 O
1 3 R
1 3 5
2 4 R
RubberFrog
Low-1st-2nd-3rd-Overdrive-Reverse
vs
1st-2nd-3rd-4th-5th-Reverse
Different gear ratios. The first pattern has a granny gear with no fourth and an overdrive. Sounds like a work truck trans. The second is just a standard 5 speed.
RubberFrog
It's not a matter of one being better than the other, they just serve different purposes.
The first one would be better for a work truck or towing a trailer. The second one would better for towing and performance.
R
reds
italy
cummins 5.9
if you have any information on the knob and gear nv4500, please put the link because the subject interests me
thanks
R
reds
italy
cummins 5.9
hello
which oil do you recommend for manual transmissions?
Can you recommend a oil for cummins engine ?
thanks
Terrence
Oklahoma City, OK
for oil you might try Mobil 1, Chevron, or Shell Rotella those are some of the major brands they are all pretty good oils in my opinion
stevenmicheal
