disappointed
shortround
Honesdale, Pa.
I have a 12 ram 1500 Bighorn with the 5.7, I ran my truck in my fairs truck pull and It kept shifting out of first gear on me. my ? is can I get it to stay in first.
S2kiHemi
Houston TX
You can keep it in first with autostick. Do you have a column shifter or a floor shifter?
Trupiano
Registered User
6.7L CTD
How were you trying to keep it in 1st gear? With the auto gear select?
Also be careful how much you pull with these gasoline 1500's. It's not a diesel and the frame isn't that made as strong as the 2500/3500's. Moved to 4th gen section.
S2kiHemi
Houston TX
When you have the truck in drive, move the shifter to the left to select 1st gear. The truck then won't shift up unless you shift up to 2nd ect.
S2kiHemi
Houston TX
Maybe you are reving it too much and its just up shifting to protect the tranny.
GhostRam94
Hunstville, Texas
2009 Laramie CC
Well if the truck is shifting out of first you prob don't need to be in first anyways;)
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The trans is trying to save itself when it upshifts, kinda like a non tuned truck trying to hold first, it only works till it hits the limiter twice then up to second she goes.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Most people I know don't pull in first gear
There aren't any programmers for your truck either
garner
Harker Heights, TX
What rpm were you going up to? If you hit around 5600 rpm it will shift out of that gear since that's redline
Sagebrush2500
2013 2500 Big Horn
My friends think I'm crazy for buying a 3/4 ton truck for the manual trans. I had a 2010 1500 with an automatic that drove me crazy with its constant up and down shifts.
stevenmicheal
