Mendonjo
- Feb 8, 2019
- 14
- 3
- Location
- Tennessee
- 1991, 1985, 1986
- 318
Hello Everyone.
I picked up an 86 D150 this week in non running condition. The seller said the truck needed a new cam, the distributor worm gear was bad and the distributor could not keep time - like it would intermittently mesh with the cam (I know the oil pump drive gear actually meshes with the cam). He had replaced the distributor with a new one and was in the early stages of disassembling the engine to get to the cam.
I set the no.1 cylinder to TDC and checked the location of the rotor. It seemed to be pointing right at the no. 2 cylinder. I turned the engine over for a few seconds and brought the no.1 cylinder to TDC. The rotor was again pointing at the no. 2 cylinder. I did this for a total of 4 times and the rotor position was always at no. 2 cylinder.
At this point I'm hoping the cam is ok and somehow the oil pump gear got out of time.
Is it possible to retime that gear with the intake manifold still on? I'm hoping I can reach down to the slot for the distributor tang and lift out (with some reverse rotation) the gear and then put it back in so the slot is pointed at the no. 1 cylinder. Or maybe I'm all wet here and the cam worm gears go bad. Any advice would be much appreciated.
Joe
Joe
