DIY: 2013-2016 (some 17-18) RearView Mirror Upgrade & Harness install
HighShyGuy
Seattle, WA
6.7L Cummins
Benny confirmed part 68309105AA is for a 2018 2500 with dual zone ATC, rain sense, auto high/dim, with NO cab lights.
I have it on order and will update when I get it installed.
How hard do I twist to get the old mirror off... I really don't want to break it off the glass...
I see it says counterclockwise, but man...
Mpgrimm2
Mpgrimm2
Preferred Vendor
Anderson, SC
2019 Laramie QC (5th Gen)
5.7L eTorque
I haven't done the swap in about 5yrs now...
Here's a video... start at 2:20 mins in the video.
Installing Radar detector using mirror power in 17ram1500
blake292
UPPER Michigan
6.7 Cummins HO
I'm looking to update my '13 3500 Big Horn to a mirror w/ Auto High Beams. Truck currently has the 911/Assist AutoDimming Mirror. Should this be as simple as installing a new mirror (911/AutoDim w/AutoHighBeam Mirror: - 68096094AA) and using AlfaOBD to activate? Is a new harness needed?
Mpgrimm2
Mpgrimm2
Preferred Vendor
Anderson, SC
5.7L eTorque
If you already have a factory 8.4 (or 5.0") radio with only a BuCam that displays on the radio, then it should be a direct swap and you should have the correct harness for the swap.
If you have BuCam displayed on the mirror ... It's the wrong mirror harness/connector and the new Auto High beam mirror doesn't have a BuCam display... & 2013-15 8.4 radios Will only display one video input BuCam or Cargo (default if installed) requiring either SW v17.11.x or a 16+ 8.4 radio to display both.
blake292
UPPER Michigan
6.7 Cummins HO
Thank you. My BU camera displays on the 8.4" radio. I'll search for a mirror and try it out.
blake292
UPPER Michigan
6.7 Cummins HO
It was as simple as plugging in the new mirror, and activating with AlfaOBD. Works great. Thank you for the guidance.
HighShyGuy
Seattle, WA
6.7L Cummins
I can confirm part 68309105AA is the needed harness for a 2018 Ram 2500 tradesman to add rain sense and auto-high beam.
This harness has high-beam and rain-sense plugs WITHOUT cab lights.
OnlyCesar
Mexico
Do I need the 8.4 radio to enable the auto-dimming and auto-high beam features? I have an aftermarket radio and I was wondering if a can enable those features with alfa obd
