cyclevolution
Thanks for the reply... the fuse you checked was it part of the cameras harness or in the trucks fuse box?I ended up checking the fuse for the camera and must’ve blown it. Changed the small fuse and it worked. Hopefully this works for you.
I will check this tomorrow. Was doubting myself, thinking I was missing something in the alfaobd software, but maybe not, it has to be a wire issue or a fuse as you said.
Sent from my SM-G950F using Tapatalk
