Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
DIY - add Auxiliary switches to a 2016 RAM 2500 Tradesman
Discussion in '4th Gen DIY' started by abbttb, Jan 9, 2017.
  1. Fishstickz
    Fishstickz Senior Member
    568
    311
    Jul 20, 2017
    Oklahoma
    Ram Year:
    2006
    Engine:
    3.7
    1. After watching one of the videos posted above, yeah the switches are removable with a little work
    2 & 3. From the same video, it looks like it they can be moved around a little. However the top row and bottom row have different shapes to them so they may not be able to swap with each other. Also the ones on the end that curve around probably wouldn’t swap either. Also you’ll have to do some wiring to make sure the buttons you change the positions of match up with the wiring
    4. It also looked like from the video that every button (including the unused boxes) have the circuitry behind it, so I would imagine those circuits have to output somewhere
    Thank you to the guy who posted those videos earlier. It looks to me like the only difference in part numbers between all these switch banks is the faceplate and buttons—all the electrical appear to be there no matter the part number. Since these switches are so easy to take apart and swap buttons, I doubt it would be too hard to make some custom buttons with some fab work
    Have one of you guys taken apart your old switch bank without the aux buttons? Im kinda wondering if the circuitry is behind those as well
  2. GTyankee
    GTyankee Senior Member Supporting Member Military
    77
    1,262
    1,802
    Nov 2, 2020
    El Cajon Calif. 92021
    Ram Year:
    Engine:
    3.0 ecodiesel
    I recall one youtube video, where the guy changes around the buttons
    You all do know that you can install the aux switches, but afterwards you have to activate it, either by going to the dealership or using a capable scan tool or programmer
    Once it is activated you can use the radio to set the functions
  3. Fishstickz
    568
    311
    Jul 20, 2017
    Oklahoma
    Ram Year:
    2006
    Engine:
    3.7
    You’re 100% right on a typical OEM swap, but my rig is about 7 years to old for that lol
    I’m looking to put a 2013 switch bank in my ‘06. Since 2013s were hard-wired and didn’t have the LIN-bus junk, the hardest thing will be grafting it into place. Since everything is completely not-OEM anyways I’ll have a lot of freedom with the top row of buttons
  4. GTyankee
    77
    1,262
    1,802
    Nov 2, 2020
    Ram Year:
    Engine:
    3.0 ecodiesel
    I was just referring to changing the buttons around on the auxiliary switch itself
    I was not referring to the connections on the back of the switch
    Fishstickz likes this.
  5. Mark Moore
    Mark Moore Junior Member
    33
    Apr 12, 2021
    Marion, OH
    Ram Year:
    Engine:
    Cummins 6.7L
    So when I cut my wires behind the switch bank do I connect my new wire to the side coming from the switch bank or the side running to the switch bank? Or do I connect to both
  6. GTyankee
    77
    1,262
    1,802
    Nov 2, 2020
    Ram Year:
    Engine:
    3.0 ecodiesel
    Found on another website
    [​IMG]
Share This Page
