DIY Cup Holder Lights
Captain McGillycutty
Maumelle, Arkansas
2011 Power Wagon
This is a write up on how to make some home made cup holder lights. Very cheap no more than $10.
Parts needed:
Led lights from radio shack (they come in differnt colors) - Red LED with Holder - RadioShack.com
1.Remove front Radio Bezel (two screws in bottom)
2. Remove lower plastic trim piece below cup holders. (Just pull out)
3. Remove cup holder assembly. (4 screws that hold black "frame" piece into the area, then just pull out assembly.
4. Drill holes from bottom (9/32"). Drill the holes through both layers of plastic:
5. Enlarge the top hole big enough to fit a deep well 9mm socket through
6. Feed led wires through both holes
7. Drop lock washer and nut down the wire onto the threads, and tighten
8. Wire the LED's together
9. Tape the wiring down
10. Tie into the ignition wire ( I used the 12volt cigar lighter power because it only works with the ignition on. The pink wire is positive and the black is a ground)
Then you get this
With the holder closed a little light escaped but not enough to bother me but you could put a switch on these if you would like.
OklaHemi
new age hemi
thats pretty wicked. nice write up
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
thats how i did mine. except i went a little further and added led's on the rim on the cupholder
AWE Daniel
Banned
Holy blue light batman!! Hope you got that on a switch!
ramhunter9
P-Star Jeep Wrangler
that is a good one captain ,
dammm thats a blue light
AParrette
St Augustine, FL
3.8L SUPERCHARGED
i set the camera on a long pass so it caught a **** ton of light. it's not that bright. i can drive w/ them on at night (really i dont) if i wanted. but the red is badass
Ram Man
FL
2013 Sport
Anybody have a write up for 02-05 guys? My cupholders are not the same at all. The top of the cup holders where the lights go looks completely different
Ram Man
FL
2013 Sport
ha your crazy
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
I love how the ones in the cup holders make the dew bottles glow. This may be my next cheap project.
HKkid
Missouri
For 02-05 as AParrette, his is an 04 I believe.
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
Nice ty in toot he cig lighter. Ign, only. i would tone down a green light too match the dash. imo.
Guillz
5.7 Liter V6
How would you go about adding a switch?
AParrette
St Augustine, FL
3.8L SUPERCHARGED
make your 12+ as pwr your led's as load and ground as ground
