korby05
thats how i did mine. except i went a little further and added led's on the rim on the cupholder
where did you get the blue led's from? are they the same type as the op used?
I did something similar but slightly easier. Autozone sells a 2 pack of 8" led strips. I bought green to match the factory lights. I simply popped off the dash bezel, used wire taps to tap the power wire to the headlight switch (powered only when parking/headlights are on, and also works w dimmer) and then tapped the ground for the cigar lighter. There's already a space in here lower panel to pass the strip through. The strip is the perfect width to stick on the lower edge of the dash panel above the cup holders w the 3m tape it comes with.
Voila, nice soft green light and easy to do.
(Insert necro-thread comment *HERE*)Anybody have a write up for 02-05 guys? My cupholders are not the same at all. The top of the cup holders where the lights go looks completely different
