DIY - Homelink buttons used as AUX switches!
Hunter69
Pittsgrove, NJ
HEMI 5.7
Did this mod and works great. I used left over parts of battery tenders, so I did not have to cut the terminals that came with the wireless unit. I am using a light bar mounted to the utility rails in the truck bed and wired to the unit and a battery in an ammo case. Can mount on either side of truck or back. Real easy to recharge the battery with a battery tender. Thanks for the great idea!
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
resurrecting. There's no way to make this work off one button, is there? I have 2 buttons taken up by garage remotes.
mdifilippo
NJ
shadowhawk
Southeast WI
exactly what I'd want. Thanks!
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Absolutely!!!!!! 1 homelink for my gate, 2nd homelink for cut in tow hook lights and 3rd for bed and toolbox lights. Used this remote relay switch
F
firemedic10584
Central Fl
Awesome that you guys are using these! I'm still using my relay in my new truck - but I use all 3 of my homelink buttons so i'm stuck still just using the remote lol. So old school! haha
Heatman13
2017 Ram 1500 longhorn
do what are you wiring the the transmitter into under the dash?
Heatman13
what are you wiring the transmitter into?
Plainbroke
Kansas
Hey guys,
Recently took on the task of wanting to have an OEM switchbank in my truck but didn't want to put an aftermarket switch somewhere on my dash. So, I did some research and figured it out. I purchased this - 20 Amp Heavy Duty 12 Volt On/off Wireless Remote Control Switch - Agricultural Equipment - Amazon.com
Once it came in, I got to work.
Here's the module when it arrived - View attachment 358491
I cut the original connections off and used male/female quick connects - View attachment 358492
Pretty straight forward - View attachment 358493
Next it's time to remove the center console. These are the two screws under the little mat just below the AC controls. Just lift up the rubber piece that is there to expose the 2 screws. View attachment 358494
Next pull up the rubber piece down in the center of the console. There was only one screw here and it was a 7mm. (I believe my 2013 truck had 2 or screws here, so it may vary with your truck year). View attachment 358495
With the 2016s, the console part just lifts up. I pulled up from the back then worked my way to the front. It's just held in with retained clips. View attachment 358496
Disconnect the cigarette plug, the white piece just unclips. Then you can set the plastic console part out of the way. View attachment 358497
I decided to just mount the module under the console to keep it well within the range of the homelink buttons. Just testing it here to make sure everything is working so far. View attachment 358498
After everything worked, I secured all the connections and I mounted the module using 3M double sided tape under the dash on just a flat surface close to where your right knee would be when you're driving. View attachment 358499
Then after all that, just plug back in your cigarette outlet, put the plastic console part back on and put all 3 screws back. The remote that comes with the module is pretty much dummy proof. It has an ON and an OFF button. Simply program the ON button to one of the homelink buttons and program the OFF button to another.
Here's the video of it. I had to do the best I could making the video with my phone lol.
https://www.youtube.com/watch?v=8nHPQhgFER4
That's it guys. Make sure you use a fuse at the battery for your power wire for protection should something ever go wrong.
Hope this gives you guys some ideas. PM me if you have any questions or I'll check back on here.
Would this work? It is a 40 amp relay.
