DIY Locking floor bin latches
kad
Hudson Valley, NY
5.7L HEMI
It turns out that the latches on the floor bins on our trucks are just a marine/RV slam latch and you can get locking ones for around $12 each from Amazon, eBay, etc. (as opposed to the $100+ Mopar ones).
Disclaimer: I did not come up with this idea myself. I saw it on a forum somewhere. I cannot recall where, but the original poster just used a slam latch and cut up the bin liner to add a new catch point for the deeper latch. I did not want to do that so I merged the new locking latch with the original latch.
Original latch on the left, new one on the right:
And the same from the side. You can see the issue, the latch piece on the new one is deeper and narrower than on the original.
Both the old and new latches are held together with a simple roll pin. It was the work of only a moment with a punch and a small hammer to disassemble each.
Original, disassembled;
New, disassembled:
I used the latch piece and spring from the original and the rest from the new one. You don't have to swap the springs, but the original was a stiffer spring and I preferred that.
Reassembled:
And installed in the truck.
This is the latch I used: https://www.ebay.com/itm/Slam-Latch...BOAT-Hatch-replace-Southco-M1-41/132303759229
-K
tnmotown
California
This is perfect! Added those latches to my cart.
Thanks for the writeup
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
just bought 2 of the latches too. I may not use them a lot, but I like having the option.
NETim
Nebraska
5.7L
On order!!!!
Terry3blue
6.4 hemi
On order thank you for the write up.
shadowhawk
Southeast WI
I'm not going to trust this to lock to hold like Ft Knox, but it might help deter the quick thief. Swapped my driver side this morning. Mine came keyed alike which is nice. Not sure if they all come like that.
edit- swapped both out. took longer to drive out the roll pin than it did to swap the latches and reinstall in the truck.
NETim
Nebraska
5.7L
Way easy install. The most difficult part of the project was re-installing the roll pin after the latch swap. I too used the OEM spring as it seemed a bit heavier than the supplied one.
Anyone moderately determined will get right through it, but it's better than nothing.
Woody968
Indiana
Great write up as usual. Been thinking about doing the metal lockable doors but this may do instead.
Matt ott
Az.
6.4 hemi
Does anyone know if the door can be replaced, I tore the door off the second day I had this 16 powerwagon seems very cheap to me, plastic hinge, now I just set the door down to cover the hole so no one sticks there foot thru the floormat...
haasri
NC
Thanks for the post ordered mine and took no more than 15 minutes start to finish. Great add on keeps honest people honest!
DoughRat19
Massachusetts
2019 Classic
@kad, awesome DYI, simple yet a money saver. $101 for mopar original locks, I just got these for $23 and installed them today. Awesome work.
Reactions: kad
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
New, disassembled:
Reassembled:
-K
Big thanks to you for the write-up Keith (@kad )!
I was able to use the same parts and swap out the latches on my 5th Gen 1500 as well. Kudos!
Reactions: kad
