Do 4th gen 1500 4x4s have "active LSD" - or not?
ram1500rsm
Trabuco Canyon, CA
If you have a V8 1500 with the 8 speed transmission you probably have an active LSD, the 2500 that use a 6 speed transmission or any other truck (in stock configuration) that uses a 6 speed transmission probably does not.
Diesel’s have a higher torque / horsepower curve and therefore have a different axle ratio pairing.
The full time 4x4 off-road enthusiasts tend not to use anti-roll bars on the rear or front axle . An anti-roll bar’s intention is to keep both wheels of the same axle on the pavement which helps LSD’s perform as intended but are not much help off pavement.
I use 4low in my 1500 with a v8 and it works for most situations where extra traction is needed but I’m not rock crawling either.
If the truck is equipped with the feature it should work regardless of trans or motor. I'm almost positive It should be standard in all 4th gen RAM's 1500's and up, so 2009 and up. I'm not able to verify my comment because i never had one that old, but it's the same system Jeep Wranglers have been using for years in the JK models, so 2007 and up.
I have a 14 Hemi with the 6 speed trans, and BLD works great considering i don't have a rear locker, only the OE rear LSD
with 35's
or with 37's
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
I agree if the truck is equipped from the dealer it should work regardless,
but just a quick search will give many different options available for differentials with similar names, my experience is from browsing through diff covers and the option for the newer 12 bolt might look like the same diff but it is not.
AAM 9.25 12 bolt is not the 9.25 12 bolt found on front differentials of the 2500/ 3500
In addition I’ll provide a link to various types of LSD ‘s
I believe anything made after 09 would be considered to be electronic braking.
Jeep
General LSD documentary
ram1500rsm
Trabuco Canyon, CA
BLD is or should be standard in all 4th/5th gen gen 1500 trucks, I say should because i don't recall RAM marketing advertising the feature. it's independant from the rear diff and it's not a dealer option nor it's something you pay as an optional add-on or anything like that. it's a logic built into the truck engine management system and uses the brakes to control wheel action.
This is an old article but it explains how the system works
I think back in 2009 they started offering both transfer cases 44-44 and 44-45, the 44-44 is the best of the 2 as it clutches don't slip like the 45 so more aggressive wheeling you want the 44-44.
There was a physical LSD device which some us of have, don't know when it was offered initially. You can check if you have with your vin# here https://fcacommunity.force.com/RAM/s/equipment-listing
metalchewy
Las Vegas
2010 TRX4
4.7L
In 2009, 1500s only came with NV243 and NV246 transfer cases.
In 2010, 1500s only had MP3010, NV243 and NV246 available as transfer cases.
ram1500rsm
Trabuco Canyon, CA
So the NV243 will have a similar operation as the 44-44. Not sure how good was the 246 in terms of slipping like the 44-45 seems to do. Seems the 45 was the chitty one :). I Had the select trac 242 in my 01 Jeep GC, and that one didn't slip, the Jeep was fully open though, no electronics, no LSD. That's how you learn the ropes with something you have to fight when the axels go with one wheel in the air.
This is a 2010 RAM 1500, easy to see how BLD did it's thing back then
If we look at a fully open diff SUV vs a RAM with the BLD electronics is not even funny to drive fully open without any real LDS oe electronics unless you know what you're doing and still...Not sure what year this RAM is though, it has 2013 and up grill but between BLD and LSD is makes the job super easy
SouthernBornRebel
Tulsa, Oklahoma
Jebb
Jebb
TFL Truck just made a video showing the brake locking in action. Shows the importance of giving it steady throttle as it takes a moment for the computer to really clamp down on the slipping wheels.
This is exactly how I understood it should work - and exactly how it does work in my truck.
According to my owner's manual, even if you turn traction control off BLDS is still active. So what are all these "YouTube nay-sayers" doing that show it DOESN'T work? How are they getting stuck with some wheels spinning and the others doing nothing - like BLDS isn't working at all?
kurek
Northwest
The BLD in my 2015 has never failed to operate exactly as advertised. Combined with the factory anti-spin diff, even if somebody offered to put a selectable locking rear diff in my truck for free and buy me a sandwich I'd probably thank them and say no because I have never been in a situation in this truck where a locker would have changed the outcome. To be clear I have owned a 4x4 with selectable lockers and am aware of how they perform. The BLD feature tensions the anti-spin diff enough that it may as well be a lock on loose, wet or mogul surfaces.
I do not take this truck through rock gardens like a moon buggy so the control advantage in that terrain is a moot point.
My pretend Jeep has BLD as well and while it does work the same way, it does not include a limited slip to supplement it and that means all applications of brake to the spinning wheel necessarily cut the final drive gear ratio in half. Since the pretend Jeep has no low range transfer case and a 4 cylinder engine + light duty automatic trans it becomes very easy to stall the transmission when BLD is called into action while climbing up hill.
