Does 2007 Dodge Ram come with limited slip differential?
Beaverfevers99
Fox Lake
I’m changing rear differential gasket and oil. used vehicle did not come with manual and I’m not sure whether this truck has limited slip differential. I’ve watched video & trying out some method, such as jacking up with two stands while rotating tires.
I’d like to make sure the truck (2006 Dodge Ram 1500 slt) did not come with limited slip differential. any advice would be greatly appreciated. Ty
JoeCo
NY
You will probably have better luck getting answers if you look/post over in the 3rd generation section of the forum. You've posted in the 5th generation section (2019+) so you may not get as many responses here.
Not sure if you can look up build sheets that old but you can try to copy/paste your vin here and see if the build sheet for your truck comes up. Why don't you want limited slip?
Beaverfevers99
Beaverfevers99
Fox Lake
Oh did not realize there is different generation section. Ty kindly.
JoeCo
NY
No problem at all, common mistake. Hopefully the information will be more plentiful there for ya.
skbball06
Albany, NY
2021 1500 Classic Quad Cab Bighorn
3.6 V6 Etorque
What engine and transmission are in it? 2006 Ram 1500 SLT 4.7L V8 5 speed auto calls for LS in front and rear dif. Same for 5.7 V8 5 speed auto
skbball06
Albany, NY
3.6 V6 Etorque
Hey is this the same post for the 2006 Ram 1500 SLT? If so, both size engines with 5 speed auto trans call for limited slip additive with the gear lube front and rear according to the service guide I have access to. Hope this helps!
Beaverfevers99
Beaverfevers99
Fox Lake
It’s 2007 Ram 1500 5.7 hemi slt. That’s all I know.
Beaverfevers99
Beaverfevers99
Fox Lake
ty. Glad I did not start changing. I know nothing about additives.
skbball06
Albany, NY
3.6 V6 Etorque
It does seem more complicated than it should be! If your main concern is making sure you are putting the correct fluids and additives in the right places - google the product Universal MGC made by BG. Gear supplement compatible with conventional and LS diffs. Good luck!
MontanaHandyman
Montana
If you call a dealer with the VIN they should be able to tell you what type of differential you have.
HemiLonestar
MD
Doesn't matter. Straight out of your year factory service manual:
Screenshot 2021-07-10 at 13-46-14 Dodge Service Manual, 2008 Ram Truck Includes SRT-10 and Die...png
WY-Dave
Cheyenne, WY
6.7 CTD
The majority of the gear oils have additive already in them. It is the general thought that additive will not affect open diffs. When I had TruTracs (Torsen gear type) in my Jeeps, it was a pain to find gear oil without additive because the additive affects the bias.
On the back of the bottle it will say some statemets like, "For conventional and LS, no additive required" etc. Finding local gear oil without it is a pain(well it was a few years ago), MOPAR $$$ and some "specialty" brands were all I could find.
Hanover Fiste
NW Florida
2005 SLT, 2018 Sport
IIRC, there is a tag on or near the differential. The tag denotes ratio, and whether it is locking or not. "3L92" indicates a 3.92 ratio, with a locking differential.
