I tend to believe its mostly a problem with the lifter design or quality itself. I know others will disagree and that's fine. The lifters don't just lubricate from crankshaft splash. In fact engine manufacturers do everything they can to avoid crankshaft splash as it aerates the oil which reduces oil pressure plus the crankshaft slapping the oil reduces horsepower and mileage. This is why we run dry sump oil pans and windage trays in high performance engines. Dry sump engines basically have no oil in the pan and run fine. Many standard factory engines come with windage trays for better mileage and performance. I know people have gotten rid of the Hemi tick by using Redline oil and other additives and I'm sure they will all chime in but that's not my point. The lifter tick is caused by the lifter plunger or valve actually sticking or not having enough oil pressure to pump up and take up any excess valve lash. I'm thinking the moly additives help the lifter internals lubricate better plus I'm sure it helps the roller bearings as well. Think about this, if your engine is ticking and you can correct it buy changing the oil its Not the roller bearings causing the issue. It's an issue with the lifter internals themselves. Roller bearings don't tick, they just eventually lock up. When they lock up it starts to wear the cam lobe down to a point that the lifer can no longer adjust out the valve lash and it starts to have valve train noise. I agree with the advantages of oils with a moly additive. My engine is extremely quite with no valve train noise at all with 46k miles. I have been running standard Penzoil Synthetic. This tells me my lifters are receiving enough oil pressure to pump up and remove any valve lash that may be in my drive train. The excess oil coming out of the lifter galley should be enough to lubricate the roller bearings in the lifter. I honestly don't know why the lifters fail but I don't think it's a complete issue with the engine block casting itself. I saw a post Burla made suggesting that the Hellcat lifters will fail as well if installed in the 5.7. I personally haven't seen any instances of that but if he is correct and that has happened then my theory is wrong and its not a matter of a bad lifter design. We can debate this until the cows come home but in reality the whole situation sucks. I always listen to my engines when I start my vehicles. If there is any noise I address it. I plan on switching to Redline oil on my next change because I do agree with Burla that the extra protection on the roller bearings will help. If I hear any ticking or valve train noise at all I will tear it down and change the lifters and cam before it's an issue or I have metal running through my engine. My 98 Chevy pickup started having a very slight knock under acceleration when it was warmed up at 237k miles. You could barely hear it. I pulled the pan and sure enough one of the rod bearings was ready to go. The crank measured out fine and I replaced the rod and main bearings plus oil pump and timing chain from the bottom side of the engine. It ran fine until the day I gave it to my son in law. I love my truck and plan on keeping it so I guess my point is the only way to deal with this for now intill we know a thecexact reason it happens plus the correct fix is to use a quality oil like Redline with the additives and change it regularly, try not to idle your truck to much and listen to your engine everytime you start it and pay attention to any new valve train noise that might indicate a problem and address it quickly if you hear it.
Sent from my SM-G981U1 using Tapatalk
