door ajar light stuck on
AJMAG
new jersey
realllly dont want to replace the latch and harness...
my door ajar light is stuck on even tho the latch and everything is closed, if i take the door panel off and pull on the wires it will go off but i dont see anywhere where it could shorting out or grounding out
my question is, is there a wire i can cut to make the light go off or at least the annoying 'ding' everytime i stop and go or any other tricks? i dont feel like spening the money on a new latch cause im saving for tow mirrors
any help would be great
ramthis9501
Oklahoma
5.2 V8
Did you look behind all the door panels? Because cutting the wire won't help, that'll just keep it on. More then likely there is a bad ground or snipped wire somewhere in there. Check them all and see. If that's not it then your latch may just be jamming up or something. If so, just spray some WD-40 on it and see if that does the trick.
AJMAG
AJMAG
new jersey
iv tried wd40 numerous times never did anything its definatly in the wires im just not seeing anything. oh well i guess ill get in there with a magnifing glass or something
AJMAG
AJMAG
new jersey
that will help even when im driving?
05singlecabHEMI
Lilburn,GA
I believe so. But im not for certain. Maybe ask hemibabe to confirm that just to make sure.
AJMAG
AJMAG
new jersey
ill give it a shot thanks bro
AJMAG
AJMAG
new jersey
hell yeah it worked!
mine had a black/green wire in the driver door, and the rear driver side door is a small all black wire snipped both and no more door ajar! finally
AJMAG
AJMAG
new jersey
Scratch that the rear didn't work. Does anyone know what wire to cut in the rear? I'm assuming you can do the same as the front just don't know which wire if any
