837CFD
I have a 2013 1500 Tradesman/Express Crew Cab 4x4 with the 5.7 Hemi and power locks/keyless entry. My driver side door lock switches have stopped working and the truck randomly locks itself. The keyless works just fine and so does the passenger side switches. Sometimes after the truck has been turned off and locked I can hear the auto lock clicking trying to engage. I have tested another driver side switch which worked a couple times then would only click but not actually lock. Then it stopped working all together. I let it sit for 30 seconds or so and it would work a few more times then do the same thing. The junkyards I’ve talked to have been no help and the dealership wants $95 to diagnose it. What else could be causing the issue?
Side note: my 2011 1500 ST without keyless had this same issue. The switch was not the problem with it but I cannot remember what I replaced to fix it. Seems like a common issue with Rams.
