Door modules
Kenepo17ram
Brooksville, FL
Looking for the door modules 68225102AC Right side 68225103AC Left side to upgrade to power mirrors in a 2019 Ram 1500 Classic Tradesman and of course also the left switch
Sent from my HD1925 using Tapatalk
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Hello,
These modules and associated switch can be found within the links below
https://parts.allmoparparts.com/oem-parts/mopar-module-door-68225102ac
https://parts.allmoparparts.com/oem-parts/mopar-module-door-68225103ac
https://parts.allmoparparts.com/oem-parts/mopar-window-switch-56046826ae
I will PM you a code you can use.
Thanks,
-Benny
K
Kenepo17ram
Brooksville, FL
Kalill Nieto
Fort Lauderdale
Hi there. I am also looking for the same numbers modules to make my sport power folding mirrors work. My question is. Can I mix different number modules? I just buy a 68155773AD for Left door. Can I use a 68225102AA for right door? Thanks6f80e21b0f43d90a4c08e7d433900014.jpg
Jpercy14
Ontario canada
2014 ram 1500
I have a 2014 ram 1500 slt. Heated standard size mirrors .. I bought standard sized mirrors with blinker and puddle light and auto dimming from a 2012.. I have already hardwired in the ambient air temp sensor and it works perfectly. But my signal won't work?? Puddle light is good to go but no signal ... any idea would be greatly appreciated
Also I'm.realizeing my door module is the same.number but ends with F not D... will this be an issue for turn signals not working? Or is that a power folding option door module
VLG6963
