Door Panel Swap!
GapperGus
Pennsylvania
Pentastar V6
I recently got offered an AMAZING deal on some bighorn door panels. I know how to take the panels off, but im not sure on switching the handles out and if its even possible. if the swap is possible it would be huge and it seems simple enough cause these trucks are like legos. just wondering if anyone has done this or has any ideas on how it would go
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Typically the handles aren't included with the door panels. Are you getting chrome ones? If not, the handles stay with the door when the panel comes off.
Does that answer your question?
GapperGus
GapperGus
Pennsylvania
Pentastar V6
I figured out how to switch the door handles, unfortunately its the wrong cab size so im only getting the front doors but ill find the rear set eventually
Years ago i think i seen somebody do a write up on how to make the differant sized door panels interchange.I forget how it was done,but i think he melted the plastic rivets ,and swapped outer edges etc. He was swapping regular sized front door panels from a crew cab into a 2 door regular cab,and the 2 door regular cab trucks use a bigger then normal door panel.
I don't remember much ,but it might be worth eyeballing things up and see if you could do the same thing
Scooter372
I just watch this today. think its the one you are thinking of.
No it was a write up and it was several years ago,but that video is better then the write up was.
Here's the 2nd part to that video.
pkillian
