Door squeak fix
tman1112000
Greeneville TN
hemi
my 2015 squeaked like insaneeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeely alot when i bought the truck 3 months ago now tryed all kinds of lube as well nothing worked untill ( white lithium grease from walmart aint made a noise since )
chri5k
USA
Diesel
I put a couple of external circlips on the post above the roller and lubed it with spray white grease. Has been squeak free for well over a year.
Smokey613
Foley, AL
If that's the case, it didn't work that way on my driver door. The roller works it way all the way up the post and stays there. Then it would stop rotating due to the friction between it and the top of the post. I would lower it and lube it only to have to redo the process constantly.
Nothing has worked to stop the squeek. Not lithium grease, silicone spray, numerous other spray lubes, nothing worked except WD-40 and it only lasted about a week. Since installing my rubber o-rings it has been quiet.
B
Bigpaul13
Glad to hear it. Mine was the same. I tried everything but it always came back until I put the washer in.
joelmic
stl mo
2017 Ram 1500 Express Quad Cab 3.6L 4x4 20x9 Wheels
I went with an HNBR O-ring. Every lube under the sun & it still ends up squealing. So far no noise. It just works!
what size and from where?
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Some pretty good ideas , my question is How do you install the O ring ? Does the pin pop up ? Thanks
joelmic
stl mo
I'll come back and edit this post when I have the size after I get home but I have a generic assortment for doing Auto Air conditioning repairs that I got years ago from an auto parts store like this one
O-ring kit link from Advance Auto
Good enough for me... THNX
same $ as Advanced, but delivered to my door for free... Thnx agin
joelmic
stl mo
Got mine in 24hrs, put one on this morning and BOOM... quiet :happy107:
Octane
U S.A.
I put some Lubegard on mine after removing old grease/dirt and it's quiet for last 2to 3 months anyway
MartyZ
Lake Orion, MI
2500 5.7l Hemi
I used motorcycle Chain Lube. Its a paraffin wax compound so it doesn't drip or thin out like WD40 or other spray lubricants. I'm going on 3 months with no squeak, but its good to know about the rubber washer trick. If it comes back ill be doing this to the Ram and the wife's Journey. Something about Mopar door hinges... Every vehicle I have owned made by them always squeaked.
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
I used slide lube for rv slide outs. Lasted about a year before I had to give it another spray and truck is a daily driver.
Ram Night
Southwest, Michigan
I just put a little amzoil red bearing grease on my trucks door rollers, and it lasts for many years. :)
Justin33
Where did you get this and what size o ring are most guys using?
