Shull
My 2014 hemi 5.7 has a check gas cap light after replacing the fuel pump no check engine light just check gas cap. Any ideas?
I was replacing mine regardless, just saying that old one was definitely shot. Yes, it is the evaporative system integrity module.What is the esim? Is the vapor leak detector ? Old one sounded the same as new one shaking rocks, but the shake test isn’t the way you test those anyway.
Same exact part I used, worked and still works.I had the same message on my Dash recently. It does not always throw a code, sometimes just the message. It was just the message for a couple weeks, scanner would not detect a code and no check engine light. Then the check engine light came giving the 0456/0457 codes. I bought a new gas cap, the old one was a bit loose. In my case it was the Evaporative Emissions System Fuel Vapor Leak Detector Pump . An 18 to 22 dollar part depending what brand. Amazon link It's a Dorman part # 310-219. Boosted Motor sports did great video on replacing which helped me figure out where it was.
RAM TRUCK GAS CAP LOOSE P0456 P0457 HOW TO REPAIR
I have a 2015 6.4L HEMI that a piece of tape is what it take to fix this problem, The dealer tells me that I need a new cap, purge valve, new pump, all new plastic lines and maybe a new tank. Everything except the lines and tank have been replaced twice, then the lists continued that would have cost over $5,000. dollars, wow. I should have kept my Ford or my 2000 Ram with 500,000 true milesIs the Gas Cap from Mopar ?
You might try cleaning the underside of the gas cap & top of the Fill Tube as a 1st step
Check out the Purge Valve, if you can blow through it
It is likely bad
video:
@carservicepro P0456, how to test purge solenoid, EVAP leak, Dodge Ram EVAP leak
this for 2016 Ram 1500 Hemi, how to test purge solenoid leak off the vehicle, I just blow mouth air to confirm valve leak, code P0456 is for small leak detec...www.youtube.com
