Dripping Fluid
04RAM_3
CA
I'm not 100% sure where to put this. Since it's something under the hood, I'll start here. Went out to dinner with the wife. Afterwards, walking out to my truck we noticed a puddle under it. Did some looking around and found a very short hose sticking out of the firewall on the passenger side, below the A/C crap. I circled it in the photo. What is it? Why is it dripping water?whatisthis.jpg
BenchTest
Midwest
If it's straight water, I'd say condensate from AC. Or drain from cowl area. Again, if it's straight water, I wouldn't be worried.
04RAM_3
04RAM_3
CA
Thank you. It is straight water. I didn't think about the cowl draining. It did rain earlier
RamDiver
Marlborough, Ontario Canada
2021 DS
An AC condensate drain is a normal function of any HVAC system.
Operating your AC without enabling the recirculation damper will create more condensate drain activity, especially during high ambient temperatures.
This site has a good explanation if you're interested.
https://beckettus.com/articles/hvac-condensate-drain-lines-importance-problems-and-maintenance/
The principles of HVAC are the same for building and automotive, buildings just have the components more exposed and easier to access/repair.
04RAM_3
04RAM_3
CA
Thanks for the replies. I'm a little gun-shy about coolant leaks after blowing up my Bronco a few years ago. Can't be too cautious after all
RamDiver
2021 DS
Condensate fluid should be clear and odourless.
A quick finger dip, rub, and sniff should confirm. It would help if you got used to spotting your own condensate drain activity, it's just another feature.
