Driveline vibration question
SeabeeVet
South Central PA
Hi, all. I have a 2014 2500 CC with a 6.4 motor and 6ft4in bed. i am looking to put a Zone 5.5in lift with clocking the t-case on with 37's or adding a level on top with 40's. I talked with a shop today about this and they said their experience with anything 6 inch and over has been that there might be a vibration in 4wd even with the t-case index. I will be driving this truck through PA winters so this will be a concern.
Who has any input on front driveline vibration?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Driveline vibrations have a lot to do with choice of wheel and tire configuration. The question is- is the truck your daily driver? Will it see heavy off-road use? I wouldn’t do a 40” tire on something you’re driving all the time. A nice 37” X 13.5 Toyo R/T would probably be the go to. We have not had any issues at our shop with going 6” on any trucks.
22hemi13
Tucson AZ
2014 2500 4x4
Well. If it’s going 5.5” lift I doubt it’s off-roading very hard. The front driveshaft don’t turn unless engaged. So normal driving it will not spin. If you hardly use 4wd and it’s very occasional I doubt you’d notice anything. Now if you wheel a lot it could pose a problem. But so can 5.5” of lift.
SeabeeVet
SeabeeVet
South Central PA
No off-roading will be done with this truck but it will see snow at excessive speeds. :cool: I didn't see many vibration problems with front driveshaft posted so this seems to be a non issue.
stevenmicheal
