Driver Door Module controls?
kanstul1600
Kitsap County, WA
4.7L V8
Tried Google, but maybe I’m not using the correct words. Can anyone tell me what each of the connection ports control in the driver/passenger door module? I had to replace the side view mirrors on my (new to me) 2012 1500. The old mirrors had a black connector only, while the new mirrors had a black, and a white connector. I know black goes in number 2 (power mirror movement), and white into number 1. Just curious what port 1 controls so I know what switch to add.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
LOOK at your wire connector
They are keyed & you can't force it in the wrong hole, without breaking something
look at the shapes of the slots
kanstul1600
kanstul1600
Kitsap County, WA
4.7L V8
Thanks, perhaps my question was misunderstood. I’m not concerned with which port the white connector goes into, I was looking for what those wires ultimately control, because there was no white connector into port 1 from the mirrors that I just replaced. I was hoping for some type of diagram that lists: port 2 - power mirror movement, etc.
Digi
central us
ever get any information on this? Think one of mine is causing an issue, I can roll down all the windows except passenger front and the power mirror won't work. Trying to find out whether it's the passenger side one or the driver side module that might be bad. Already ruled out the switch on drivers side as it's brand new.
