Driver side Head light assembly?
Headlight assembly moisture?
  • replacement part?
    Votes: 0 0.0%
  • repair?
    Votes: 0 0.0%
  • Total voters
Telvis
Baltimore
Greetings RAM enthusiasts,
I was wondering what I can do to fix moisture that has gotten worse in the headlight?
I'm trying to get a oem stock number so I can research better and even look to see to replace it. But like on ebay, what appears to be the same headlight says not compatible with oem projector?
I do know its a projector style w/signal and dim/park lights are LED I believe.
Any suggestions as to what I'm looking for or fix would be greatly appreciated.
Thank you,
Telvis 2013 Dodge RAM 1500 Sport Crewcab 5.7 HEMI
(pic attached is not the correct side, its the driverside) But used this pic to describe the type of headlight.
turkeybird56
Central Texas
There are a lot of threads on this problem:
DO a full forum search: "Moisture in headlights" and then peruse and see if anything works for U. Most of the topics covers the "vents" on the 13's.
Good Luck
Welcome from Central Texas...
