driver side mirror and ac drain
LAlaramie82
New to the forum so, wanted to say hello from Louisiana!
I have some damage to my drivers side mirror. The glass is shattered, motor still works to adjust the mirror and the turn signal lens is damaged. Anyone know if i can just replace the glass and the lens without having to order an entire new mirror kit? See picutures of damage attached.
Also, I've noticed my AC drain is spitting out a lot more water than normal the past couple days. Anything i should be concerned about?
Thanks in advance from a novice mechanic! lol
7777xm
Covington, GA
I've seen people buy other damaged mirrors with good glass and replace it. There may be other places that sell just the glass, I'm not sure on that though.
Since the AC drain is just the condensed water from the outside air, it should be fine. Odds are, your relative humidity outside is starting to rise.
I'm in Georgia and our humidity is starting to get higher so there's more moisture in the air to be stripped
Sent from my SM-N920T using Tapatalk
cgeorgemo
Joplin, MO
3.6 Pentastar
My truck was vandalized just over a year ago and I ordered new mirror glass for mine. I don't remember the part numbers but I do remember the price was right about what they show on that Amazon item.
DTarve23
Princeton TX
They definitely sell just the glass ..... when I bought my sons Ram the driver side mirror glass was shattered and the dealership sent me a new one....it came with the glass mounted on the plastic backplate ...... It literally just pops off and on in about 30 seconds
stevenmicheal
