Drivers door switch panel
Six8888
Houston TX
If you have this switch panel in pictured 6EED5660-D3E3-409E-A018-FA6E57D3E680.jpegI would like to know if the part where the mirror controls are lights up with headlights on. Mine doesn’t but the rest of the panel does. Thanks
Ricks Ram
If you have this switch panel in pictured View attachment 221575I would like to know if the part where the mirror controls are lights up with headlights on. Mine doesn’t but the rest of the panel does. Thanks
No unfortunately on the Rams they do not. If your truck has the single connector on the back of the switch you can install one from a Jeep Grand Cherokee and the mirror control buttons will be illuminated. If you have the older switch with two connectors in the back unfortunately they don't make a switch panel with illuminated mirror controls for that style. I belive the 16 and newer trucks are the ones that have the single connector.
Sent from my SM-G981U1 using Tapatalk
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
OP if you have a Classic 2019 Ram, it will fit. You have one plug.
