Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
My Drivers heated seat not always working on my 2014 Ram. Anything I can look for or try to fix? Both lights come on when turned on, but no heat in seat.
Thx
The heated seat works intermittently. Usually if I turn the heated seat on and off a few times it will work. I light on the switch for the heated seat will stay on until I shut it off, but no heat.
Are the heating/cooling function controlled by the same module? The heating function works intermittently and there is no issue with the cooling function. Also the heated steering wheel works fine.
