Driveshaft orientation?
Josh22855
Any idea on the install orientation of the driveshaft, or does it matter ?
Josh22855
Josh22855
Ok, smaller diameter to front of truck and larger diameter to differential. Thanks!
Daw14
South Florida
May I ask what happened , that you need a new driveshaft ?
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
Nice, did you do a crossmember notch, and if so, where did you get it? :)
Josh22855
Josh22855
No crossmember notch, I need to load the bed of the truck with weights and see what my clearance is.
cityredneck
arlington, tx
are the single cabs the only ones that have the possible driveshaft failures?
Ashkon
Baton Rouge
Not sure but I will be changing it on my crew cab soon. I don’t trust the 2 peice shaft.
Josh22855
Josh22855
I have not heard of the driveshaft failing on the crew cab/ extended cab. I ran a stock driveshaft on a crew cab with around 500 rwhp without any issues. The crew cab driveshaft was 1 piece carbon steel though.
Marshall
Sk, Canada
2014 sport
I presume the air line is for ad on air ride?
BWL
Embrace the skeptisism
BC Canada
I'm pretty sure my driveshaft is straight.My u-joints on the other hand.:gayfight:
Only the regular cab shortbox "8speed" 2 wheel drive trucks.Regular cab shortbox 8speed 4X4's are good,and every other cab/box configuration seem to be okay.The regular cab shortbox 5 and 6 speed trucks are good to go,it's only if you have the 8 speed that you'll want to look into a better driveshaft.3.21 geared trucks aren't as prone to driveshaft failure as the 3.92 geared trucks are,the taller 3.21 gearing,keeps the driveshaft rpm down in comparision the the 3.92 geared trucks driveshaft rpm.Not saying you can't destroy a regular cab shortboxes driveshaft even with 3.21 gearing,but you'll be going a hell'va lot faster before it lets go,lol
cityredneck
arlington, tx
Ive got a crewcab, 4x4, 8 speed, 3.92s
Sent from my SM-N986U using Tapatalk
