Driveshaft spacer
brandon.colt
Rock Hill, SC
2012 1500 Outdoorsman
Does anyone have a rear driveshaft spacer on their 6" lifted 1500?
muddy12
Indiana
Same here, 6" RC, no rear shaft spacer.
brandon.colt
brandon.colt
Rock Hill, SC
Okay. My ProComp lift came with a front spacer but not for the rear. When I crawl under the truck, it looks like the yoke has moved out of the t-case about an inch or two. Im trying to figure if thats safe or if I need to find a spacer for the rear driveshaft.
Thanks for your input fellas.
muddy12
Indiana
You'll be fine. The output shaft, and splines on the yoke are long enough to account for the new position.
After a little while in the new position, the newly exposed part of the yoke will look just like the rest of it, and you won't be able to tell that it's moved out.
